oil separator
Old Jan 29, 2010 | 09:57 PM
herblatham's Avatar
Default oil separator
I was trying to pull out the oil separator, which is on top of the passenger side valve cover towards the back, correct? and it doesn't seem to budge. I'm afraid to pull any harder and break it. Does it take a lot to pull it out? I don't see how the hose could be sucking anything from the hole that the oil separator is in, because it looks like it's completely closed off...
98 land rover discovery le
140000
Old Jan 30, 2010 | 08:22 AM
XCELLER8's Avatar
YES ! That thing is very fragile......too fragile for where it goes an what it does and the fact that we're supposed to clean it now and then. I've broken mine a couple of times before I gave up and took a piece of window screen rolled and wadded it into the hole just enough to stop the oil but not the flow of air.......I've thought that someday I would plug that hole, drill another one in the valve cover and use a rubber grommet and a normal pcv valve.......someday
austinlandroverbill
Aug 23, 2015 01:03 PM
dougn
Dec 29, 2012 09:56 AM
kae
Jan 24, 2010 10:38 AM
sheelhorse
Jun 22, 2009 11:38 PM
discoboy
Feb 11, 2009 01:42 PM
