Oil Separator? Baffle? Stupid Dealer.
Old Jun 1, 2011 | 03:47 PM
humroot's Avatar
Default Oil Separator? Apparently I dont have one.
So I went to replace my "oil separator" today and took about an hour to get the old one out. It came out in 4 pieces. So I call the Dealer to see if they have a new one. The guy says the Disco II's don't have an oil separator. I described the part and he says it's called a "baffle". I was going to be a smart-*** and direct him to the RAVE manual which clearly shows it is an "oil separator" and not a "baffle". Anyway, he tells me the "baffle" is $8 and change, but he doesn't have one in stock. They come in a pack of 10 so I would need to buy all 10 for him to order it. I hate the dealer.
Just a word to let folks know that this little piece needs to be cleaned or replaced periodically or it can lead to bad things. I can honestly say I have never replaced mine, so I bet it's original and never been cleaned in 120k miles. Shame on me....
Old Jun 1, 2011 | 03:57 PM
buick215's Avatar
You should know by now that you can't count on the dealer for anything. Contact roversnorth, atlantic british, will tillery, etc. if you need a part.
Old Jun 1, 2011 | 06:07 PM
lordmorpheus's Avatar
If you have a local Carquest, check there. At least the Carquest here can order from WorldPac, which stocks them. (and you can buy them individually, 1 day delivery, and usually no freight charge)
Old Jun 1, 2011 | 06:16 PM
KenR's Avatar
So where is this oil seperator installed on the truck? I hadn't heard of this before but I'm a noob.
Old Jun 1, 2011 | 06:20 PM
humroot's Avatar
It's similar to the pcv valve. It's located on the passenger side valve cover. Remove the hose connecting the intake to the valve cover and the oil separator is in the tube.
Old Jun 1, 2011 | 09:10 PM
Your Uncle Spike highly recommends cleaning the oil separator no less than once a year, more than twice a year is over kill unless you have a problem.
Old Aug 26, 2012 | 08:40 PM
928paul's Avatar
Default replace oil separator
can anyone post photos of oil separator? or link to the manual many thanks! need to replace oil separator asap thanks again.
austinlandroverbill
Aug 23, 2015 01:03 PM
greenharoguy
Feb 19, 2013 08:52 PM
dougn
Dec 29, 2012 09:56 AM
humroot
Mar 12, 2010 06:31 PM
Newfoundlandrover
Sep 18, 2007 02:09 PM
