Oil separator part number
Old Jun 3, 2021 | 10:30 PM
redwhitekat's Avatar
Default Oil separator part number
Did the mod today on my pcv but bent that metal tube that goes into valve cover. Where the plastic oil seperator sits in.
anyone have a part number for that metal piece or have a spare valve cover around I can buy it ?
04 disco
Old Jun 3, 2021 | 10:33 PM
I’m going to try and cut the tip off where I bent it actually. But I still might need one
Old Jun 4, 2021 | 06:10 AM
mollusc's Avatar
It's literally just a piece of metal tube. The outside diameter is important (so that it will press-fit into the cover) but the inner diameter doesn't matter, so see if you can find any pipe at a hardware or plumbing supply and cut it to length.
Old Jun 4, 2021 | 06:32 AM
well after i flipped it arounf to pres it in it goes but im not overly confident, thanks for the tip
Old Jun 5, 2021 | 01:35 PM
Richard Gallant's Avatar
@redwhitekat get some red or better strength locktite or epoxy and run a bit around the base of tube where it hits the valve cover. It never needs to come out once you have done the mod.
Old Jun 5, 2021 | 01:56 PM
good tip thanks
redwhitekat
May 7, 2018 06:29 AM
DiscoBuckeye
Apr 16, 2016 10:28 AM
eedisco
Dec 31, 2015 09:27 AM
batard
Nov 16, 2015 06:43 AM
dougn
Dec 29, 2012 09:56 AM
