Oil Separator Removal ... ?
Old Feb 5, 2011 | 04:12 PM
discoklein's Avatar
Default Oil Separator Removal ... ?
Hey everyone, getting ready to remove my oil separator and replace it with a new one along with the 2 new hoses for it. Are there any tricks to removing the separator...? does it unscrew out or does it just pull out of the sleeve it sits in on the valve cover... thanks
Old Feb 5, 2011 | 04:21 PM
lordmorpheus's Avatar
It is supposed to just pull out. When I changed mine the other year, it snapped in half, and I had to remove the remaining part with a 90* pick.
Old Feb 5, 2011 | 04:33 PM
Very small pair of needle nose pliars.
Old Feb 5, 2011 | 05:33 PM
discoklein's Avatar
Thanks for the heads up.... I tried to remove it today with my fingers but she seems to be frozen pretty good. Mike, I am going to try your idea you gave me over the phone as to using carb cleaner to get her cleaned out. I have never done the sea foam treatment to this vehicle as I did on my other one last year. That might help things out as well. Thanks for the info to both of you.
Old Feb 5, 2011 | 06:08 PM
SDinDS's Avatar
Good luck. Mine was stuck in there. I used a center punch and hammer and drove it out.... of course, this was during my rebuild so the valve cover was already off. I wouldn't recommend doing it with it still on!
Eric
austinlandroverbill
Aug 23, 2015 01:03 PM
eedisco
Oct 14, 2013 08:34 AM
dougn
Dec 29, 2012 09:56 AM
sheelhorse
Jun 22, 2009 11:38 PM
discoboy
Feb 11, 2009 01:42 PM
