Height sensor questions
Old Feb 5, 2011 | 10:29 AM
wsroufe's Avatar
Default Height sensor questions
I have had Disco II 99 since last Aug. I have done a few things but it's had a lean to it (toward the driver's side) since we got it. On occassion it has gone all the way down and then pumps back up when car is started.
Ideas? Doesn't seem to be leaking so my first assumption is the height sensors. I am considering conversion to coil springs - but would rather go with a cheaper option.
As always thanks for your help.
Old Feb 5, 2011 | 10:37 AM
tee51397's Avatar
You've def got an air leak somewhere. You can try the soapy water trick and hope it's something free. If the car constantly lists to the drivers side your ride height may need recalibrated- that's if it never corrects. If it leans overnight and is then correct after a pump-up then at least you know where to start looking for the leak.
Old Feb 5, 2011 | 06:17 PM
At your mileage, if you have never changed your bags, that would be the first thing to do, consider 2 new bags from Arnott industries.
Have any questions send me your number and I'll call you.
mirepoixmatt
Nov 12, 2021 05:48 PM
houm_wa
Mar 31, 2016 12:57 AM
tinawilson
Oct 6, 2012 11:13 AM
charles21
Feb 21, 2011 11:08 AM
