Oil sump gasket recommendations?
Old Dec 27, 2014 | 07:10 PM
zski128's Avatar
Default Oil sump gasket recommendations?
Going to swap my oil sump this week and will need to replace the gasket. Besides RTV in the proper places, does any one recommend a gasket. The Victor Rienz gasket from RockAuto looks interesting...or is OEM the way to go?
More Information for VICTOR REINZ OS32343
Thanks!
Rich
Old Dec 27, 2014 | 07:39 PM
binvanna's Avatar
I use The Right Stuff all away around and it works great with no pre-formed gasket.
Old Jan 6, 2015 | 07:10 PM
zski128's Avatar
Picked up the Victor Reinz gasket. Was under the truck making sure I had everything I needed to get this done and noticed there might already be a Victor Reinz gasket in there plus a very generous amount of RTV from the PO. Any one tried using thread sealer on the sump bolts? I tightened these once before and they are loose once again...some I can undo with my hand.
Old Jan 7, 2015 | 06:01 AM
drowssap's Avatar
i would put a thin bead a black RTV on the whole gasket surface, after it sets you could lose every bolt and it wouldnt leak
Old Jan 7, 2015 | 10:40 AM
5kcstq's Avatar
I used the VR gasket and it has sealed pretty good. However, my bolts do tend to loosen as well. I've been under there twice now to cinch a few down. May pull them and blue loctite them next time.
Old Jan 7, 2015 | 02:55 PM
golgafrinch's Avatar
How is the Right Stuff for removal? Is it hard to remove to clean mating surfaces?
Old Jan 12, 2015 | 03:00 PM
zski128's Avatar
Got the new sump installed this weekend and was pretty straight forward, I did notice I am missing a bunch of sump bolts mainly the 3 shorter ones connecting the sump to the bell housing...will have to track those down. Will see how we do on leaks now. The PO sure RTV the hell out of the old gasket, it took me over an hour to break the seal and get it off as it was glued tight.
Had one other surprise, this was my first oil change since doing head gaskets a few months back and found some coolant in my sump! Not a huge amount but now I know where it was going as I could not find any external leaks. It was never enough to show up on the dip stick.
Old Jan 12, 2015 | 03:01 PM
zski128's Avatar
Plastic scrapper and a lot of blades
tito5590805
Apr 28, 2020 12:53 AM
powderhound
Apr 11, 2015 11:40 PM
golgafrinch
Jan 5, 2015 10:33 PM
knightmetro
Jun 10, 2014 02:49 PM
mike111
Jun 2, 2014 08:58 AM
