Oil in Throttle Body
Old Jun 12, 2010 | 08:49 AM
kenk's Avatar
Vacuum pulling off the passenger's side, through the engine, in thru the drivers side
Old Jun 12, 2010 | 08:53 AM
kenk's Avatar
Originally Posted by Spike555
Well fine then!!
You are right and I am wrong, you make a very valid point.
Trust me, no offense meant. When mine plugged, I stopped by the dealer for a $5 oil seperator and got schooled like a 3rd grader for half hr on how it works. Lets just say I got it down pat now...
Old Jun 14, 2010 | 03:44 PM
DeepBlueWater's Avatar
Thanks for all the good input guys. I've been very busy the past few days and haven't had time to explore the problem. Hopefully I'll be able to get under the hood tomorrow.
I'll post what I find.
Michael
Old Jun 14, 2010 | 05:26 PM
Non taken man.
Old Mar 15, 2018 | 03:21 PM
Matthew P Sweeting's Avatar
Hey what did you do to fix this? My truck threw a p0123 code so I wanted to clean the throttle body and it was pretty bad. Seemed like oil was coming up from valve cover but not sure
Old Mar 15, 2018 | 03:23 PM
Saturnine's Avatar
This thread is 7 years old.
Old Mar 15, 2018 | 05:01 PM
Best4x4's Avatar
In 7 years no one has figured out a bolt on PCV for the passenger side. I did my own research and have found the FV308 to be a perfect solution. 100% bolt on PNP compatible. Remove plastic/metal nipple from Intake, install FV308, and remove the plastic baffle from the passenger valve cover and call it a day.
Old Mar 15, 2018 | 11:47 PM
Saturnine's Avatar
Tftw!
Originally Posted by best4x4
in 7 years no one has figured out a bolt on pcv for the passenger side. I did my own research and have found the fv308 to be a perfect solution. 100% bolt on pnp compatible. Remove plastic/metal nipple from intake, install fv308, and remove the plastic baffle from the passenger valve cover and call it a day.
Old Mar 18, 2018 | 01:22 PM
Twix's Avatar
Vacuum in the plenum pulls the air through since the air in front of the throttle plate is under atmospheric pressure.
This is why if the separator is clogged, the throttle plate will pull air from the crankcase which under load, just not through the separator. Hence why you'll see oil in the intake or on the throttle plate
Old May 6, 2019 | 08:20 AM
Coker Stephen Aksana's Avatar
My 2005 Freelander 2.5 has been pouring oil into the throttle body since I owned it, I have replaced the throttle body before once it became so made, cleaning didn't help it. Is this along the same line as the guy with the discovery? I have also replaced the MAF to Throttle Body Air Duct Hose. I been told that I need a Catch Can to catch the oil from from the crankcase breather hose. But, I should not be getting that much oil through the hose in the first place, and it seems to be getting worst, especially in going over the mountain road in Kyrgyzstan.
