OK guys help with the first code of many
Old Feb 13, 2009 | 03:47 PM
discodefender's Avatar
Default OK guys help with the first code of many
PL441 Evap emissions purge flow
Have to download software to read the amigos codes. This is the SES problem.
Many thanks in advance!
Old Feb 13, 2009 | 04:29 PM
okdiscoguy's Avatar
Check your gas cap and fuel lines.
You have to have a rover compatible scanner to read abs codes
Old Feb 13, 2009 | 07:14 PM
Will replace the gas cap. Fuel lines are fine. Was told to replace purge valve on other forum.
Have a high dollar scanner that needs a euro upgrade. It is a buddys.
Am I missing any other ideas?
Thanks
Old Feb 13, 2009 | 07:24 PM
Mike?
thanks
Old Feb 13, 2009 | 07:31 PM
Here I come, cut me some slack, I am still trying to figure out all the new bells and whistles.
Here is a link for the 441, http://www.landroversonly.com/forums...e-441-a-29389/
Doubt you will find any software to rear the 3 amigos. I will be testing a new device that can read and clear D2's ABS issues, later this month.
Mike
Old Feb 13, 2009 | 07:33 PM
many thanks
Old Feb 13, 2009 | 07:56 PM
malmberg's Avatar
When my purge valve was bad it was hard to put gas in the tank. If you are having trouble filling up your tank then it could be the purge valve. That is about all I know on that.
Old Feb 13, 2009 | 08:04 PM
that happened twice in a 1500 mile trip. 9000 ft altitude change though and the tank was very empty. Thanks for the advise.
Old Feb 14, 2009 | 02:13 PM
got it. Hyudia part # 2891022040
lots less money and everything is good!
Discolife
Dec 2, 2011 03:44 PM
jasoncrew03
Nov 15, 2010 09:48 PM
Paulpen
Feb 2, 2010 05:05 PM
MRDM1
Mar 16, 2007 07:03 PM
phia@binoco.com
Dec 10, 2006 11:23 PM
