OK... might have found a Disco!
After looking around and around, I have run across a few candidates for my next silly purchase.
I'm going to look at a 2003 (VIN is after the bad oil pump range) on Wednesday. Looks to be a single owner with 100K on the clock. The color is the Beige/Gold which I don't like, but color is the least of my worries. The truck looks clean inside an out, and well taken care of. Looks like it has lots of the dealer installed extras as well (brush guard, driving lights, rear ladder, side steps, etc).
So, during the test drive... what should I really listen to/hear/feel? I have read all the "what to look for" posts, but interested in the real meat of big red flags to notice. I already know I will most likely have to do the gasket, greasable shaft, fluids, etc... but what are big dollar items I need to sweat while looking/driving her?
Thanks!
Thanks!
Also, would testing the HDC on a regular (non dirt) hill show anything?
make sure it can shift into and out of hi-lo put it in lo and down in 1 and get one side of the truck up on a curb and hit the HDC come off the curb and you should feel the brakes engage as each tire comes off the curb. if you are just pavement and engage the HDC it won't do anything unless there are loads of potholes and manhole covers to hit.
Basically make sure everything works.
A wet grass hill is a good place to check the traction control.
Basically with the Hill Decent Control and Traction Control if there are no warning lights on on the dash then it all works, if it has the "3 Amigos" then the rule of thumb is the TC, HDC and ABS do not work.
I've been trying to find pictures of these but can't. I'm assuming it would be something fairly obvious to see looking underneath? The usual nipple type grease fitting?
Good tips so far everyone! It is much appreciated! Looks like there might have been some paint work from the pictures, as the "SE7" badge on the Driver's Side is not there. I'll see the CarFax and have a good look in person though. Any other suggestions please let me know!
