OK... might have found a Disco!
Old Oct 25, 2010 | 01:45 PM
Snafu / Disco Fries's Avatar
Default OK... might have found a Disco!
After looking around and around, I have run across a few candidates for my next silly purchase.
I'm going to look at a 2003 (VIN is after the bad oil pump range) on Wednesday. Looks to be a single owner with 100K on the clock. The color is the Beige/Gold which I don't like, but color is the least of my worries. The truck looks clean inside an out, and well taken care of. Looks like it has lots of the dealer installed extras as well (brush guard, driving lights, rear ladder, side steps, etc).
So, during the test drive... what should I really listen to/hear/feel? I have read all the "what to look for" posts, but interested in the real meat of big red flags to notice. I already know I will most likely have to do the gasket, greasable shaft, fluids, etc... but what are big dollar items I need to sweat while looking/driving her?
Thanks!
Old Oct 25, 2010 | 01:51 PM
NiteTrain's Avatar
look for engine leaks..check 4lo..try to find some dirt or gravel and see if TC kicks in
Old Oct 25, 2010 | 01:56 PM
OK, so try out 4Lo on the pavement to make sure it goes in and out smooth, correct? With the dirt/gravel, should I be in Hi or Lo, and just try to free up the tires to see if it kicks in?
Also, would testing the HDC on a regular (non dirt) hill show anything?
Old Oct 25, 2010 | 02:09 PM
agthird's Avatar
put it in 4 low on a steep driveway push the HDC switch and let it go down the hill with your foot on off the brake...you will know if it is working
Old Oct 25, 2010 | 02:11 PM
agthird's Avatar
pull the dipstick check oil level....check coolant level...check door locks...check sunroofs for operation...see if front driveshaft has been replaced or has grease zerks on u joints...
Old Oct 25, 2010 | 02:12 PM
hilltoppersx's Avatar
make sure it can shift into and out of hi-lo put it in lo and down in 1 and get one side of the truck up on a curb and hit the HDC come off the curb and you should feel the brakes engage as each tire comes off the curb. if you are just pavement and engage the HDC it won't do anything unless there are loads of potholes and manhole covers to hit.
Old Oct 25, 2010 | 02:20 PM
Basically make sure everything works.
A wet grass hill is a good place to check the traction control.
Basically with the Hill Decent Control and Traction Control if there are no warning lights on on the dash then it all works, if it has the "3 Amigos" then the rule of thumb is the TC, HDC and ABS do not work.
Old Oct 25, 2010 | 02:36 PM
I've been trying to find pictures of these but can't. I'm assuming it would be something fairly obvious to see looking underneath? The usual nipple type grease fitting?
Old Oct 25, 2010 | 02:38 PM
NiteTrain's Avatar
this pic is not from a rover but it will look very similar
Old Oct 25, 2010 | 02:53 PM
Good tips so far everyone! It is much appreciated! Looks like there might have been some paint work from the pictures, as the "SE7" badge on the Driver's Side is not there. I'll see the CarFax and have a good look in person though. Any other suggestions please let me know!
