Ok, springs came, now what?
Old Jun 10, 2014 | 08:34 AM
sDot's Avatar
Default Ok, springs came, now what?
I finally got a set of DII springs and mounting hardware to replace my faulty bags, so I called my local shop and they can't quote me because they want me to come in so they can figure out how to milk me for as much as possible.
So I know some guys do this on their own, but I don't have a spring compressor or anything crazy. Is this really the 30 minute job that people say it is?
Are there any detailed pictures, instructions floating around?
Old Jun 10, 2014 | 08:40 AM
dusty1's Avatar
there are some videos, i think. you can do it w/o spring compressor, prolly have to unhook shock.. your axle should drop far enough with the frame on jack stands and a small bottle jack placed between the frame and axle (bump stop location)
yes you can do it and yes it is a fairly easy job.
Old Jun 10, 2014 | 08:42 AM
ZGPhoto's Avatar
It's not a 30 minute job the first time you do it, but you don't need a spring compressor and it's really easy.
Old Jun 10, 2014 | 08:47 AM
jafir's Avatar
Yeah, especially if you are installing stock springs, they go in pretty easily. The HD terrafirma springs had me fighting them.
The hardest part for me was tapping the holes in the axle housing, because I was using a cheap greatneck/autozone tap.
Old Jun 10, 2014 | 09:04 AM
WNYErikDiscoII's Avatar
Former Sponsor
If you do go to a trusted shop, it shouldn't take them more than 2 hours
Old Jun 10, 2014 | 09:12 AM
You will need to have a shop turn off the SLS thru the ECU to prevent battery drain and dash lights. What are you doing about shocks, have they already been replaced, if not this should also be done to help control the new coils.
Old Jun 10, 2014 | 09:56 AM
sDot's Avatar
Can't I just pull the fuses? Can any shop turn off the SLS or just a Rover shop? I had no idea about the shocks.
Old Jun 10, 2014 | 10:03 AM
dusty1's Avatar
some have problems, some don't with the fuse pulling. testbook or the like is needed to delete sls from system. dealer or not, as long as they have the equipment. I pulled fuses, relay and all sls components. I have no drain, but I do have a goofy raise the rear light, on the dash. and I have received the speed actuated chime that goes along with it, on a few occasions.
Old Jun 10, 2014 | 10:12 AM
Ditto!
rchrd0413
Apr 22, 2014 02:18 PM
greg409
Aug 17, 2012 12:03 PM
hockeymom1
Dec 22, 2011 11:21 AM
kaczman
Feb 4, 2007 04:22 AM
