OK Tear down time
Old Sep 4, 2011 | 01:13 PM
MrFlea's Avatar
Default OK Tear down time
I have decided to investigate the ticking noise from my motor. I have looked at the exhaust and tightened the bolts and replaced the manifold to pipe gasket(both sides). Still ticking can be heard. I am planing to replace lfiters,push rods, and the rocker arms. I also am going to replace the cam and the timing chain assy. I don't feel that the noise is a slipped liner....BUT won't know till I get it apart. This is going to be a learning experience for me so I may be asking questions in the future. Any advise will be greatly appreciated. I have a 2001 LR II with a 4.0. I want to use all OEM parst and keep it original. Thanks in advance
Old Sep 4, 2011 | 06:49 PM
94svt50's Avatar
It should be fun but, remember people have replaced every moving part only to still have the tick.
Old Sep 4, 2011 | 07:39 PM
On some of the other forums very respected member gurus have detailed a process of pinning the liners, so they won't slip in the future, supposed to be about $100. Consider doing the oil pump, rear main seal, front crank seal while you have things apart. That assumes you are pulling the engine. But if not, some can still be done. Have also seen write ups on crankshaft bearings done in the truck. Eventually it will be better than brand new. There have also been recent posts on the tick that involved the SAI, might want to review those before turning a wench, er.. wrench.
Old Sep 4, 2011 | 10:01 PM
atancreti's Avatar
Replace the oil pump, timing chain and sprockets for sure! Do you know if its top or lower end noise? Maybe its a bearing??? The lifters and rockers/ pushrods are pretty easy as long as you have the rave.
Old Sep 4, 2011 | 10:07 PM
atancreti - what about your oil PSI and oil pump?
Old Sep 4, 2011 | 10:15 PM
MrFlea's Avatar
I get the tick after it has run for 10 min or so then it is at idle and low speed. Cannot hear it from in the car but can hear it outside. I have heard bad lifters before and this is a simular sound. Tried lighter grade oil but no difference. Will look into the SAI also. Thanks for input.
Old Sep 4, 2011 | 11:54 PM
ruffram's Avatar
Any pictures of this? I have mine torn down to the bare block right now and I am very interested in getting the liners pinned but can't figure out how to search Discoweb.org to find the posts or and pictures
Buddy Lee
Oct 2, 2014 10:04 PM
n1keaddict
May 11, 2011 06:46 PM
shonuff93
Feb 20, 2010 10:23 PM
dgilaon4
Jul 7, 2009 08:40 PM
