Ok, what's missing here
Old Feb 8, 2016 | 12:20 AM
Bom2oo2's Avatar
Don't need to remove cluster to check bulbs,, they should light-up when you turn ignition key to start position & then go off when car starts,, if it does that then bulbs are ok,
If lights don't come on at all then you have a problem,!!
Old Feb 8, 2016 | 12:21 AM
number9's Avatar
As suggested it would be a god idea to see if light illuminate during a normal light/system check per the owner's manual.
Old Feb 8, 2016 | 05:14 AM
drowssap's Avatar
i believe some of the replacement abs sensors went right back to the ecu eliminating the plugs
Old Feb 8, 2016 | 11:14 PM
Shoebox's Avatar
8th Gear
Thanks for all the suggestions guys, all lights are working and no faults at all. I believe it was bypassed eliminating the plug.
Old Feb 9, 2016 | 01:20 AM
cmthompson's Avatar
8th Gear
Get the flywheel inspection plugs from the dealer.. I want to say they are $13 a piece.. No sense trying to source a used one, as they will not go back in after they swell with time and oil.
Old Feb 9, 2016 | 01:46 AM
number9's Avatar
Good advice. New one will install with little effort versus fighting to get old/used in and one day beneath vehicle it's found to be missing.
jbarr89
Jul 12, 2011 12:10 AM
dig4dave
May 21, 2010 10:04 PM
MortgageGuy
Feb 22, 2010 09:53 PM
Jeff Eades
Apr 10, 2009 11:51 PM
tony kerr
Dec 18, 2004 05:09 AM
