OME with bags
Old May 29, 2007 | 02:32 AM
95DiscoSE7bullitt's Avatar
Default OME with bags
I installed some old man emu shocks and medium duty springs up front. Now with my new springs that are suppose to be factory ride height OME springs. Now the front end sits about 3" higher than the rear. If I use he offroad button for the bags it is completely level until you get up to 20mph it lowers again. Is there anyway to over ride the lowering bags at that speed? Never have seen anything about thatwas hoping I could I like the higher ride height bu sagging rear does not look good. Bags are working fine and have been but I wondered how therear air bags level themselves, do they level compare to the to weight on them or is there an internal leve just for the back, or does it try to match the front height in some way?
Old May 29, 2007 | 08:06 AM
Default RE: OME with bags
There is only one fix for your problem which is to buy a set of 2" spacers, made by http://www.rovertym.com/ .
Thes will allow you to lift the truck at least 3"s withount blowing out your air bags. You will also need to install 2 new shocks in the back of the truck to keep everything in control.
Mike
Old May 31, 2007 | 11:58 PM
Ok so if I put these spacers under the bags how do you let pressure off the bags to put the spacers under them. Would I unhook the battery then just let jackstands sit on the frame?
Old Jun 1, 2007 | 07:21 AM
No, you don't unhook the battery, all you have to do is bleed down the air pressure, mount the new lower mount and the adjusters and let the system air back up.
When you get to that place, call me and I'll walk you thru the installation, takes less the 1/2 an hour.
Mike
303-862-7680
greg409
Feb 23, 2012 04:47 PM
Spencerfitch
Apr 27, 2010 06:03 PM
dammad
Apr 19, 2007 07:53 PM
tripz
Jan 4, 2007 05:58 PM
tripz
Feb 7, 2006 06:03 PM
