Are OME crap shocks?
Old Nov 24, 2014 | 01:27 PM
abran's Avatar
Default Are OME crap shocks?
I have a set of OME shocks with a verified 60K miles on them and they have no rebound. I can easily depress them and it will take at least a day(maybe more) for it to rebound.
My mechanic has a set, not sure of the mileage, and I depressed one of his and it never came back.
Whats the deal? I had a set of unknown mileage Bilsteins that were a bear to depress and rebounded immediately.
I always thought they were the best, but my mechanic says they are glorified Monroes.
Any similar experiences?
Old Nov 24, 2014 | 01:37 PM
ZGPhoto's Avatar
<similar experience
worse experience with TF, at not even a quarter of that lifespan.
The_OGCJR's Avatar
OME are usually good shocks.
Old Nov 24, 2014 | 05:32 PM
Big Jim Swade's Avatar
I've got OME's on my Discovery and I think they are great. I've got adjustable Rancho 9000 series on my Nissan Frontier and they are crap after 24k miles.
Old Nov 24, 2014 | 06:16 PM
Dave03S's Avatar
How many miles do you have on your springs?
Shocks will crap faster if you have original stock coil springs.
Years and tonnage take their toll and stock D2's have neither on their side at this point. I personally killed a set of Bilsteins in 10k when I put them on my sagging stock springs at 120k. Ride was great at first, then quickly turned to crap.
If you gotta upgrade the shocks, consider upgrading your springs as well.
Old Nov 24, 2014 | 06:53 PM
dusty1's Avatar
Well, why not just drive very very slowly.
Old Nov 25, 2014 | 08:55 AM
OffroadFrance's Avatar
IMO there are very few good shocks that take big punishment. KYB being the largest manufacturer and their top end are good, equally Koni and Bilstein are top makes and performers particularly the top end re-valve type that can be stripped and rebuilt by specialist pros, but they ain't cheap. The rest are personal choice on the mass produced market place. In shocks you only get what you pay for!
Old Nov 25, 2014 | 09:38 AM
Jagfixer's Avatar
I bought SPAX and one crapped out. SPAX replaced it, so I moved the SPAX from my D1 to my Classic, then bought Bilstiens for the D1 which lasted over 100K. OME are supposed to be good, check warranty, they may honor replacement.
Old Nov 25, 2014 | 10:43 AM
jafir's Avatar
Only gas shocks rebound (OME are gas shocks), but it isn't really a design feature. The gas is there to help keep the fluid under pressure, so that is bubbles or foams less. A side affect is the rebound. The shocks probably still work ok, they just won't stand up to continuous heavy duty use if the nitrogen is missing now. The bubbles created from heavy use will degrade the performance.
Old Nov 25, 2014 | 01:45 PM
abran's Avatar
That explains some. The car they came off of rode nice, the springs are OME as well and it had a stiff ride but no bouncing, etc. I have a second car with a set, again unknown mileage, I will post my findings once I remove them.
