OME Lift Installed, Passenger Rear Lower
Got my OME 2 inch lift installed last night, ive got the 779 front hd/medium frton springs and the 781 medium duty rears. Installed A on driver side b on pass side both front and rear, and rubber isolators on top of springs front and rear. Vehicle rides great, everything is seated correctly, rear sway is disconnected. The passenger side rear is sitting about an inch lower than the other 3 corners? Any tips?
Found this on arb site. In vehicles with front and rear A/B springs, most of these vehicles will be happiest with an A coil fitted to the front, driver corner and the opposite rear, passenger corner. In vehicles with only rear A/B springs, most will end up with the A spring on the rear, driver corner.
Maybe i just swap the rears?
andrewmcoffin
03-24-2008 10:29 PM
