OME Lift Installed, Passenger Rear Lower
Old Nov 28, 2013 | 08:50 PM
lmcgrew79's Avatar
Default OME Lift Installed, Passenger Rear Lower
Got my OME 2 inch lift installed last night, ive got the 779 front hd/medium frton springs and the 781 medium duty rears. Installed A on driver side b on pass side both front and rear, and rubber isolators on top of springs front and rear. Vehicle rides great, everything is seated correctly, rear sway is disconnected. The passenger side rear is sitting about an inch lower than the other 3 corners? Any tips?
Old Nov 29, 2013 | 07:49 AM
lmcgrew79's Avatar
Found this on arb site. In vehicles with front and rear A/B springs, most of these vehicles will be happiest with an A coil fitted to the front, driver corner and the opposite rear, passenger corner. In vehicles with only rear A/B springs, most will end up with the A spring on the rear, driver corner.
Maybe i just swap the rears?
Old Nov 29, 2013 | 08:47 AM
dusty1's Avatar
that would be my suggestion. i didn't realize my tf springs were left right specific, till after I had installed....just got lucky in the placement.
caymandrew
May 9, 2015 10:05 PM
sddisco
Mar 25, 2014 03:10 PM
yloDiscoII
Mar 19, 2011 11:52 AM
andrewmcoffin
Mar 24, 2008 10:29 PM
LRDISCO
Feb 1, 2008 12:04 PM
