ome spring kits
Old Dec 31, 2008 | 04:45 PM
jon67's Avatar
7th Gear
Default ome spring kits
hi all first time posting. I have been lurking for some time and finally have a question I cannot find and answer to. I am installing an ome spring and shock setup. I have installed the 762's in the rear and have moved on to the fronts. they are 767's. I noticed the new ones are 2" shorter than the old ones. I see that they are much stiffer but I am still wondering if they are the right ones. Can anyone confirm for me if this is correct? thanks in advance
95 disco from north vancouver bc[:-]
Old Dec 31, 2008 | 06:10 PM
Default RE: ome spring kits
There is no such thing as a 767 OME spring, check out this link.
https://www.expeditionexchange.com/ome/indexsprings.htm
Old Dec 31, 2008 | 06:30 PM
jon67's Avatar
7th Gear
here is a link to the OME website. Ignore the picture as it is a generic pic for all their coil springs
http://www.oldmanemu.com/search.html...;submit=Search
Do you know if the OME springs are usually shorter for the front? I know the 762"s were longer by 1" over the stock ones on the rear.
Old Jan 1, 2009 | 09:29 AM
OK, I stand corrected, I wish all these links would get there act together.
Yes, on a D2, the front coils are shorter, that is why many of use who want a taller lift go to the 751 which is the front HD coil for a D1, it is an inch plus taller.
As for if they will work, can't answer that, just have to try them and please let us know how it turns out>
Old Jan 1, 2009 | 08:19 PM
jon67's Avatar
7th Gear
well I just finished my suspension upgrade. The OME 767 were 14.5 and 15" tall, kind of short compared to other OME springs, but they still lifted my truck about 3". So I got 3" higher on the front and the rear. The two sides are also now even so I am happy that I got the right springe on the right sides. Took it for a drive in the snow here in North Van and it soaks up the bumps much better than before. An added bonus is that my ABS light has gone out, I guess she liked the way I pulled her wires while I was under there.
Old Jan 1, 2009 | 08:49 PM
You should be so lucky, they will be back on.
Take care,
John Frederick
Apr 1, 2014 10:26 PM
AtlanticBritish
Member Group And Special Buys
Mar 10, 2011 10:17 AM
southfloridadiscoII
Jun 18, 2009 08:48 AM
mrossipir
Jun 15, 2009 02:53 PM
steve125
Motorcars LTD
Jul 2, 2007 11:33 AM
