OME spring question
Old May 13, 2009 | 01:51 PM
mrossipir's Avatar
Default OME spring question
Need advice on which OME springs to buy. I am trying to get a full 2 inches of lift from my 2000 Disco II and want to buy the OME heavy duty springs since I am adding a new bumper and Warn winch. I also use the car to tow both a heavy utility trailer and a boat.
Which OME springs should I use?
751 (from a Disco I) front / 762 rears
766 front / 763 rears
or another combination.
I dont mind if the ride is a bit harsh.
Old May 13, 2009 | 02:46 PM
No question, 751/762's are the only way.
The front will hold that extra weight and not collapes and the 762's are pretty much an equal for height.
Old Jun 15, 2009 | 01:20 PM
mrossipir's Avatar
Will I need to shim the 762's in the rear if I use the 751's in the front from a D1?
Old Jun 15, 2009 | 02:53 PM
Are you going to be installing a winch and bumper?
If no, yes you'll need to put a spacer under the 762's, if you are going to be installing the winch and bumper then that weight will pull the front end just about level with the rear 762's.
oysterhead
Apr 12, 2010 08:42 AM
Jason_B
Mar 22, 2010 07:00 AM
lipadj46
Aug 18, 2009 08:28 PM
southfloridadiscoII
Jun 18, 2009 08:48 AM
jon67
Jan 1, 2009 08:49 PM
