OME spring selection question
Old May 18, 2021 | 11:44 PM
Discorama's Avatar
Default OME spring selection question
OME uses the following convention:
  • 0LBS TO GVW
  • 220LBS TO GVW
  • 440LBS TO GVW
I didn't find an explanation what that means in particular. Is it load over GVW or is it load from to GVW?
Currently I have all stock. I want stronger springs in the back. On trips the Disco is loaded with 3 kids, stuff in the trunk to the ceiling and I have load on the roof (about 100-150lbs) as well as a hitch carrier (about 200lbs). When I add up everything it is about GVW, but not more.
It's not a daily driver, although I use it for driving short distances in town.
Are 220LBS TO GVW (2762) springs too hard? How do they compare to TF?
Thanks.
Old May 19, 2021 | 12:42 PM
greisinb's Avatar
I'm nearly certain this means weight added to the GVW capacity. I've been researching this exact same thing for the exact same reason (fully loaded disco for a trip this summer). I don't DD mine but don't want a crap ride either when it's not loaded up so my current plan is put D1 spring spacers in the back for a very slight lift.
Old May 19, 2021 | 01:58 PM
Discorama's Avatar
Currently I have air helper springs in the back and that compensates for the sag and supports the load. I want better off-road capabilities over stock and replace a worn out suspension. I just would like to know if 2762 (HD in the back) is horrible or not when driving empty.
Old May 19, 2021 | 02:58 PM
zski128's Avatar
I have the OME HD springs you mentioned above with OME Nitro shocks and yes it is a bit stiff unloaded. It reminds me of an F250/350 unloaded. I had about 400lbs in the cargo area recently and it was a lot smoother but not like stock springs for sure. The sagging was minimal. It was 400lbs of dirt in bags for a garden and decided to experiment with the D2 versus a pickup.
Old May 20, 2021 | 05:25 AM
SundayFunday's Avatar
I have the HD OME currently in my rear (220lb+) of my 04 - Every so often I’ll drive it for a few days/week to put some miles on it - use it for beach & overland. I have a permanent drawer system with tools and equipment - a fridge &/or cooler is packed typically when I take it out.
I find the HD springs are not bad whatsoever. Loaded it handled very well. Not really any sway or too rough. I did all the math & can easily calculate additional tare weight over stock GVW (empty) with what I would be leave in my truck semi permanent, vs packed up on top of that (GLVW) gross loaded vehicle weight.
currently I have the drawer system pulled out and trunk gutted - as I’m converting a new build onto another d2 - since March I’m driving around with gutted rear end on HD springs (using fox shocks) and I honestly really don’t feel much difference in stiffness. I have a stock D2 which I lm converting and that rides on air bags which is apples and oranges - but the stiffness of the HD is really no problem whatsoever -
infact I have the EXTRA HD /440lbs springs in a box im going to install on new build - I have a rear steel bumper from RTE with a swing arm & larger tire to add weight & my new drawer system is a little heavier. So my I need to see for myself about the spring difference.
Every day. My daily for work is a Ford 250 & 350 pickup. So I’m quite literally hopping out of the empty disco these days into to pickup and there is ZERO comparison. The disco still rides like a disco, & no comparison to stiff suspension as a pickup.
I wouldn’t be intimidated - I had to see for myself too. The OMe have held up very well. Good paint, good ride.
Old May 20, 2021 | 05:27 AM
I would like the weighted spring conversations on here to pizza. Everyone has a different personal opinion on what they feel is the best.
Idioteque2
Mar 9, 2016 03:32 PM
rchrd0413
Apr 22, 2014 02:18 PM
drowssap
Sep 27, 2013 07:04 AM
XCELLER8
Nov 4, 2009 08:55 PM
lipadj46
Aug 18, 2009 08:28 PM
