coolant change out
Old May 19, 2021 | 05:48 PM
Tomzsix's Avatar
Default coolant change out
How often does everyone change out their coolant? Or perform a coolant flush? Would yearly be obsessive? It's been two years since my Turner engine install, and don't want to screw it up.
Old May 19, 2021 | 06:05 PM
Best4x4's Avatar
Greeen stuff is good up to 5 years/150,000 now
Old May 20, 2021 | 06:48 AM
Big Jim Swade's Avatar
Most coolants (even dex-cool) is rated for 5 years. But the way Disco's leak and things go wrong (like thermostat's and water pumps) I don't see how anyone could not change it sooner just because of the random things going wrong requiring to drain the coolant.
Old May 20, 2021 | 09:21 AM
Sean Maginness's Avatar
This is me.
I also have a Turner in my 03. Between swaping plastic for metal parts in the cooling system, the T bleeder failing, and trying out different thermostats and set ups my coolant is been changed and changed again likely an other time all with in a few years.
Old May 20, 2021 | 01:04 PM
Discorama's Avatar
A flush makes more sense when replacing the radiator with a new one. The stuff collecting at the input the lower channels won't come out with a coolant flush.
Old May 20, 2021 | 03:15 PM
Jason_B's Avatar
Its pretty easy to disconnect the lower rad hose, let it drain, raise the res, put 1 or 2 bottles of coolant in there until it is gushing out the bottom, reconnect it and bottle it all back up. Don't forget to bleed!
You will get at least 50% of the coolant with this quick flush method and doing it every year or so would keep the coolant fresh.
LR2driver
LR2
16
Sep 1, 2021 10:03 PM
Fastercat
Dec 21, 2017 01:44 PM
malmberg
May 13, 2010 09:58 AM
Gavster
May 13, 2009 08:43 PM
bigugly82
Aug 23, 2007 04:32 PM
