OME springs
Old 03-08-2016 | 02:41 AM
Idioteque2's Avatar
Default OME springs
So I inherited an almost complete used OME suspension (rear springs only, plus all 4 shocks, 107 and 108). Problem is I can't determine if the rear springs are heavy or medium duty. Can't seem to find any markings. Is there any other way to determine this? I was hoping the 107/108 shocks were specific to a certain load capacity, but apparently it's used for both heavy and medium duty. Lastly, how can you determine what side it goes on?
Thanks again...
Old 03-08-2016 | 05:42 AM
drowssap's Avatar
then taller spring goes on the drivers side,
you might take measurements and check on there web site,
possibly you can see the difference between them that way.
Old 03-08-2016 | 08:37 AM
Charlie_V's Avatar
Dro I can't tell of you are joking or I am learning something new. The taller spring goes on the drivers side? When I did my springs there was a difference front to back but not driver to passenger.
Old 03-08-2016 | 08:48 AM
drowssap's Avatar
i thought is strange too,
but when i was doing my classic it stated in the manual that the taller spring goes on the drivers side,
presumably to account for the driver weight.
if yours were the same size, i'm guessing they were not OME or ARB springs.
Old 03-08-2016 | 08:49 AM
OverRover's Avatar
He's right. OME, Terrafirma, etc all do the same.
OP, this link has some spring specs > land rover spring specifications
Old 03-08-2016 | 08:53 AM
drowssap's Avatar
nice graft, that's going with the favorites
Old 03-08-2016 | 09:06 AM
Charlie_V's Avatar
No I went cheap and got TF. There were zero instructions with them so, per usual, I made a guess and forged ahead. It never occurred to me that the different heights went on sides rather than front to back.
I'm skinny so I guess it doesn't matter. I hope it doesn't matter!
Old 03-09-2016 | 03:32 PM
Idioteque2's Avatar
Thanks for the link! Yes, there's a slight difference between the driver and passenger side, between 1/4 to 1/2 an inch. Measured my springs and it looks like they're medium.
Thanks again!
Spencerfitch
04-27-2010 06:03 PM
humroot
11-13-2007 11:16 AM
bklahl
08-15-2007 08:19 AM
rravenn13
06-22-2007 11:28 AM
newBrover
03-24-2007 07:11 PM
Quick Reply: OME springs
