Ome or super gaz ??
Ome or super gaz ??
HEY Guys !!
My '98 DI with 150,000 mi. is starting to "sag" we use her 90% highway but tow a little and some off road stuff occasionally.....have any of you installed the super gaz stuff ( shock & spring kit) ?? and do you like the results ?...or should I stick with the ome ?
with stock size tires I'm thinking I would like about 1' lift
There is only one person I know of on this forum that has installed the Super Gaz kit (I'm blanking on who it is right now) and their initial reports were good. I personally am a OME fan because that's what I have installed on my truck and I know it works well. For the usage you describe you could probably go with a medium duty OME kit and be just fine. It will take care of your sagging problem and give about 1" lift.
A far better longing laster?.................. Getting SG isnt like buying an El Rancho.. The guy said He did 90 percent on the road .. Why does he need a $1000 setup ...Please Explain to the difference to my between my Super Gaz and the infamous OME.. Gaz is Britpart and OME is Australian.... Seems to the Aussie version is the lookalike
on
First of all, OME set up can be bought for about $100 more then a set up from SG.
Bottom line, they have more history a better selection and will out perform Big Blues and SG's, that is just the way it is. I understand you want to defend your selection, and that is fine, but some are better then others, just as some RTE set ups are better the OME and then there is Safari Guard, which is trying to make a come back and no one is sure where they will fit in.
on
Yes, to each his own, and when you get 10% of the trail mileage under your belt, you may see why nearly everyone uses OME, and RTE's and if someone asks me, I will tell them as I see it.
When was the last time your saw another set of Blues or SG's on another vehicle? I am a member in 2 Rover clubs consisting of around 450 trucks, no yellow knock offs and only an occasional set of Blues.
If you check around you will find your price comparisons are off. Luck 8 has the OME set for $599, Atlantic British has the SG set for $579!!
