OMG my AC Clutch
Old Mar 11, 2014 | 08:53 AM
Lou02Disco's Avatar
5th Gear
Default OMG my AC Clutch
I was driving one day then suddenly a thumping noise came from under the hood. I pulled over and found the clutch to the AC was sitting on top of the radiator housing. The pulley is still on and the bolt that holds the clutch s gone. Should I replace the clutch or the whole AC unit to fix it?
Old Mar 11, 2014 | 09:23 AM
drowssap's Avatar
you can just replace the clutch and front seal if you wish
Old Mar 11, 2014 | 02:43 PM
Dane!'s Avatar
Just buy a bolt and put it back on, you have to get a washer to fit in between the shaft and clutch, use locktite on the bolt when your putting it back on. If your clutch bearing is going you can get one from autozone for the ac clutch hub.
03discoman
Sep 2, 2009 04:32 AM
03discoman
Apr 27, 2009 09:54 AM
aBs0lut30
Jul 21, 2008 04:54 PM
88 rover
Feb 19, 2008 10:45 AM
seanpage86
Jul 6, 2007 09:57 AM
