One of AC Vents Doesn't Blow
Old Jun 20, 2009 | 11:41 AM
evoking's Avatar
Default One of AC Vents Doesn't Blow
Since I bought my 99 I I have noticed te right vent on the center of the dash doesn't flow any air. The little lever that either opens or closes the air flow seems to be broken as it moves freely.
So I'm wondering if it somehow broke while in the closed position? I see those little vents for sale on Ebay but not sure if the vent includes the lever or if its the culprit.
Any ideas? Is this a common issue?
Old Jun 20, 2009 | 12:07 PM
AK Rover's Avatar
The switch come detached from the mechanism that opens and closes the vent pretty easy. You'll more than likely need to pull the center dash section out to repair it.
Old Jun 21, 2009 | 05:50 PM
evoking's Avatar
Any how-to's or writeups on how to do this?
Old Jun 21, 2009 | 06:48 PM
So the vent is broken?
The part that you can see with the grills on it?
The part that you can move to direct the air flow, thats what you mean?
I just want to be clear.
Old Jun 22, 2009 | 02:30 AM
evoking's Avatar
The part that determines whether the airflow is letting air through or blocking it is what moves freely. This is NOT the vent itself in terms of the swiveling etc.
Old Jun 22, 2009 | 09:03 AM
Just replace the vent.
They pop right out, the hard part will be getting a new one, may be a dealer only item but it should only cost a few bucks.
Old Jun 22, 2009 | 04:58 PM
jmt's Avatar
jmt
Is this a D1 or a D2?
I can't speak for a D1, but on a D2 if you'll take something like a pen and push it back into the right side of the vent, it will open.
Your switch won't work but it will blow air.
Old Jul 1, 2009 | 06:12 PM
evoking's Avatar
Where exactly would I try pushing? Upper, lower, center?
Old Jul 7, 2009 | 01:49 AM
jmt's Avatar
jmt
Lower should work.
discoklein
Mar 13, 2013 12:30 PM
bullcrew
Jan 22, 2012 10:39 PM
Miwo
May 4, 2011 08:40 AM
Paul Grant
Oct 19, 2010 07:10 PM
Eak69
Apr 4, 2010 11:52 AM
