One problem after another after 3 Amigos appeared!
Old Feb 29, 2008 | 10:08 AM
NJDisco's Avatar
4th Gear
Default One problem after another after 3 Amigos appeared!
Hi all,
Bought my 03 disco from the dealer with 12,000 miles on it. Have taken excellent care of it (as dad is a huge car and rover enthusiast). Well, 67k miles later, the 3 amigos appeared. [:@]I hate these things. Got a new left rear hub and the amigos went away--for about a month, that is. They appeared again soI took itto our local land rover specialty shop where they replaced a sensor (the short one) and was told if it happens again, I'll need the longer sensor that goes around the entire car. Next day I notice squeaky brakes that escalate to a loud squeal anytime pressure is put on the brakes. At this point, it's embarassing to brake, especially in the quiet suburbs. Took it back to the shop again (its become my second home now) and now need new rear brakes. I just got new brakes about 8 months ago! This car is driving me insane! We have a 99 discoverythat has never ever had any of these problems so this is a huge disappointment.
I'm new to the forum but does anyone feel as if there's one problem after another with their vehicle?
Old Feb 29, 2008 | 10:28 AM
Default RE: One problem after another after 3 Amigos appeared!
So get rid of your noisy brakes and your problem will go away. Everyone knows yuou can't run pads that are either dusty and or noisy or you will be plagued with the trio.
Old Feb 29, 2008 | 10:33 AM
NJDisco's Avatar
4th Gear
Yes, will "obviously" get rid of noisy brakes, however,my point wasbrakes were fine before the sensor was replaced.And if, "Everyone knows yuou can't run pads that are either dusty and or noisy or you will be plagued with the trio" there probably wouldn't be so many threads about it.
Old Feb 29, 2008 | 10:35 AM
jdelp's Avatar
I wonder if we hear this more often due to people using new harder composite brake pads w/ worn rotors, thus causing squealing and vibration? My thinking is either replace the rotors w/ the pads, or if you're looking to save $$ and don't want to replace the rotors then use something like mintex pads that are softer and will conform to the worn rotors.
Does this logic pan out? Curious to hear others thoughts. Either way, I'm replacing both when I need new brakes.
Old Feb 29, 2008 | 10:37 AM
NJDisco's Avatar
4th Gear
Thanks for the input. I definitely plan to replace both-
MarkSF
Feb 16, 2014 03:46 AM
ljdiscovery
May 16, 2010 02:23 PM
JAC
Oct 2, 2009 09:41 AM
jun.prieto
Jan 5, 2008 01:33 PM
gwalker
Apr 14, 2007 12:03 PM
