only front wheel drive
What makes you think that the rear wheels arent moving? Have you checked your tranny AND transfer case fluid level?
I'm not sure how that indicates pulling only with the front wheels.
In any case, it sounds like your juice box is low (slipping). Fill it. If it still slips, you probably smoked the torque converter or the trans.
Ok the front right is the only tire trying to spin the others don't even try. I ordered a new Shuttle valve switch for my amigos (mine failed the above sticky test), but was also under the assumption that I would have normal 4 wheel drive but with out the traction control when the amigos where on. And I'm not scared as I'm new to Rovers what is a CDL and how do I lock it. I'm assuming it locks in the 4 wheel drive somehow. Go ahead and flog me....LOL its the only way to learn.... Thanks for the help guys!
Scott
Scott
