Ooops...to much splish splashing
I'm surprised (and sorry) that a little splashing is leading to trouble, I watched the video and it didn't seem worse than what you would encounter after a heavy rain- the D2 should be able to handle more than that! I once had mine up to the bottom of the headlights in a butt clenching moment in an off road park and even though I came out unscathed I'll never do that again!
@greisinb it was not the depth it was the speed, @cerpindicular going fast through water leads to problems. Check your coils, air filter and the area around the plug that are mis-firing you will likely find moisture. I have seen trucks literally die in the middle of water 6 inches deep just from going too fast, looks cool but not a good idea.
The Deputy
Nov 11, 2020 06:15 PM
