Ooops need a quick Drive-shaft Answer!!
Old Apr 12, 2014 | 04:38 PM
parkerlander's Avatar
Default Ooops need a quick Drive-shaft Answer!!
99 disco II
Have had the drive-shafts off for a few months while doing some other tranny work....Forgot which side of the shaft goes to the Diffs!
Is it the side that extends when greased or the other side?
Thanks!
Old Apr 12, 2014 | 05:22 PM
ZGPhoto's Avatar
The single u-joint goes to the diff, in the rear you may still have a rotoflex, which would also go to the diff.
Old Apr 12, 2014 | 09:29 PM
the rear only i meant.......one side has
the joint that slips in and out .....they both have a single union so ???
Old Apr 12, 2014 | 09:48 PM
dusty1's Avatar
aftermarket. should only go one way but short slip end should go to the forward of the truck
Old Apr 12, 2014 | 09:59 PM
ok great thanks, that's how I had it but it mounts both ways!
I had it in one way then flipped it around. after two full days putting a new (used) tranny and all the bs that goes with it my brain is fried!!!!!
cwjl2011
Jun 5, 2011 05:23 PM
NiteTrain
Sep 27, 2010 07:48 PM
endneu913
Nov 3, 2007 03:46 PM
LPs HSE
Jan 17, 2007 02:36 PM
