opinion on 3 issues, skid,tire and alignment.
Old Apr 14, 2012 | 03:16 PM
94svt50's Avatar
Default opinion on 3 issues, skid,tire and alignment.
All right, wanted to get your alls opinion on a couple issues as I get the rover ready for a 1500 mile round trip to the beach. 1). I have the plastic skid plate/under engine cover off from a previous repair and was wondering if it was better to leave it off for maybe better cooling or put it on for better aerodynamics on the interstate? 2) Im replacing one back tire due to a side wall cut with a new tire, the rest of the tires have about 4k miles on them. Should I lower the psi in the one new tire by a psi or two to equalize the size of the new tire to the slightly worn older tires? 3) I just replaced the front drag link and steering damper shock but, I was careful to adjust the new bar to the old bars settings. Should it be realigned? If im off a thread or two on the tie rod ends would that throw off the alignment?
Thanks for your replys and opinions.
Old Apr 14, 2012 | 03:24 PM
The "skid" plate can be left on or left off, makes not much difference, it actually does aid in engine cooling while you drive because it creates a wind "tunnel" in the engine compartment.
But you can leave it off.
Dont worry about the tire size difference, it is not big enough to matter.
Yes you need a alignment before the trip.
Dont over think it man, its just a truck.
Old Apr 14, 2012 | 03:34 PM
94svt50's Avatar
if I talk to it nice will it not break down?
Old Apr 14, 2012 | 08:30 PM
What size tires do you have? Depending on that will determine how much you can air down while on the sand.
Old Apr 14, 2012 | 08:45 PM
Yes, that is the key. You must talk nice to her, pat her on the hood and whisper "you're a great truck, keep up the good work"
ninjaff21
Jun 19, 2014 10:43 AM
wheelgarage
Dec 28, 2012 10:28 AM
Cirrus
Aug 31, 2010 05:06 PM
JavaRacer
Oct 1, 2009 04:07 PM
jomeheretu11
Oct 31, 2005 06:55 AM
