Opinions needed - should I replace the metal coolant elbow with a new one?
Old Jan 12, 2022 | 08:04 PM
Brandon318's Avatar
Default Opinions needed - should I replace the metal coolant elbow with a new one?
In the middle of a head gasket job and replacing crusty things along the way. The coolant pipe that goes into the intake manifold is disgustingly rusty inside. Been on the maybe list for a while and wondering if I should just go for it. It's not cheap for what it is, like $200, hence the waffling back and forth.
New one here for reference...
Old Jan 12, 2022 | 08:11 PM
Alex_M's Avatar
If it's not leaking and there are no obvious thin spots I would continue to use what I had.
If there are obvious thin spots then I would consider taking the piece to an exhaust shop. Good chance they could weld you a new piece of pipe to the original flange. Or weld it up yourself if you have the capability.
Old Jan 12, 2022 | 08:36 PM
tnrangerover's Avatar
Call up will at Roverguy.com and get a non-Rusty used one. Probably $30 or so
stuckntx
Jan 12, 2015 09:10 AM
gusbone
Oct 7, 2012 09:10 AM
xxjtvxx
Jun 29, 2012 06:23 AM
Satisfying Pie
Jan 8, 2011 11:24 PM
tommytwotone
Dec 31, 2009 07:04 PM
