Options for transmission cooling hoses
DiscoJay99 (11-28-2022)
You can make them yourself with flexible hose and barb fittings (hose shop, car performance shop, hardware store). I don't think there is a lot of pressure on the transmission fluid system. Anyway, I made engine oil cooler lines myself since I added an oil cooler. For the cooler connections I used 14mm compression fittings. The system runs at 50psi and has absolutely no leaks.
mln01
04-26-2020 04:24 PM
