Options for transmission cooling hoses
Old Nov 28, 2022 | 08:47 AM
DiscoJay99's Avatar
4wd High
Default Options for transmission cooling hoses
Have any of you had lucky sourcing some transmission cooling hoses? They’re discontinued and I haven’t been able to find them anywhere, this DII is my winter daily driver and I need to put away my summer car asap. Any help is appreciated, thank you.
Old Nov 28, 2022 | 10:01 AM
Harvlr's Avatar
I just replaced my engine oil cooler hoses on my P38. I got them from LR Direct in the UK. I would have thought the trans hoses were also available but I didn’t check on those.
Old Nov 28, 2022 | 10:19 AM
zski128's Avatar
If it’s just the rubber ends and connectors you are taking about there are threads on here about getting new fittings pressed on the steel line at a hydraulic shop. The lines are no longer available.
Old Nov 28, 2022 | 01:43 PM
Discorama's Avatar
You can make them yourself with flexible hose and barb fittings (hose shop, car performance shop, hardware store). I don't think there is a lot of pressure on the transmission fluid system. Anyway, I made engine oil cooler lines myself since I added an oil cooler. For the cooler connections I used 14mm compression fittings. The system runs at 50psi and has absolutely no leaks.
Old Nov 28, 2022 | 02:05 PM
sqlbullet's Avatar
Flex hose and barb fittings is what most aftermarket trans coolers ship with, so it should be fine.
Old Dec 22, 2022 | 10:21 AM
Xanthro's Avatar
You'll choices are 1. Fabricate a new one. 2. Get a used one. 3. Replace it with something else.
There are no new ones available.
I had my slip off twice, and a replacement had to be fabricated.
Old Dec 23, 2022 | 07:38 PM
H Hill's Avatar
Had to replace mine. Went to a hydraulic hose repair company with the old hose. They fabbed a new one. Worked great.
Old Dec 27, 2022 | 10:54 AM
TimInNova's Avatar
Call Trailhead. They make very nice custom ones: https://www.trailhead4x4.com/services
Westminster02
Jan 15, 2022 08:01 AM
jagmandan
Oct 30, 2020 05:39 PM
gus93shook
Apr 27, 2014 02:43 PM
bennycisco
Aug 9, 2012 08:56 PM
