Orange multiplug under coolant reservoir
Old May 2, 2013 | 07:55 AM
Dan7's Avatar
Default Orange multiplug under coolant reservoir
Just did an engine swap. Don't remember unplugging anything there, but there's an unconnected orange multiplug under the reservoir. What's it for???
Old May 2, 2013 | 08:25 AM
Perhaps something came loose from underside of fuse panel.
Attached Thumbnails Orange multiplug under coolant reservoir-d2-underside-fuse-panel.jpg
Old May 2, 2013 | 01:58 PM
Dan7's Avatar
I'm fairly certain it goes to SLS. Compared it with another 04...only difference being he had SLS and I did not and his was plugged in and follows the frame rail all the way back to the rear axle. Can't find that plug anywhere in the RAVE though.
Old May 2, 2013 | 06:02 PM
Madlands's Avatar
My 99 that had SLS has it plugged up, but my 04 with stock coils there's nothing plugged into it. Not positive that it's an SLS plug or not though, but it sounds like it.
Old May 3, 2013 | 09:48 AM
Dan7's Avatar
Here's the pics (taken with the reservoir removed from cradle):
Old May 3, 2013 | 11:24 AM
SuperSport's Avatar
Learned a month after buying it that I didn't have SLS either, and I have the same plug UN-plugged.
Old May 3, 2013 | 12:07 PM
Dan7's Avatar
Perfect! Now change out your dexcool for the yellow stuff
Old May 3, 2013 | 12:18 PM
SuperSport's Avatar
Actually, I did a flush and change when I changed my Thermostat to Motorad 439-180. The overflow bottle is stained orange, so you cannot really tell. I now run a very comfortable 195 degrees most of the time.
I used this:
Attached Thumbnails Orange multiplug under coolant reservoir-coolant.jpg   Orange multiplug under coolant reservoir-motorad-439-180.jpg
Old May 3, 2013 | 08:21 PM
Here some SLS system plugs for that area - go to the valves. Would have to verify by connector end layout and wire colors. Attached. C0377-C0391
File Type: pdf
04duxlr
Nov 13, 2013 06:54 PM
akbarkhan
Jun 9, 2012 07:12 AM
RROJ
23
Dec 1, 2010 12:53 AM
