Our 2001 Project DII
Old 08-29-2018, 09:12 AM
DiscoBuckeye's Avatar
Originally Posted by Charlie_V
Haha!!
A mechanic told me to check the heads at home by pouring water in them (off the truck) to see if any gets past the valves. Not the most scientific test but I've done it a couple of times and you can tell when the valves are not seated properly.
I am going to try this but I will use lighter fluid so what ever does not leak through, I will set on fire just because...
  #202
Old 08-29-2018, 02:06 PM
Charlie_V's Avatar
Talking
I like that way of thinking!
  #203
Old 09-01-2018, 10:41 AM
So I'm cleaning up the front of the block and I see these two blue/green paint splashes. Certainly we put nothing past the factory when they made these badboys however, it made me wonder if it meant anything. Thoughts?
  #204
Old 09-01-2018, 10:52 AM
duscarter's Avatar
Just cleaned mine off and saw the same thing.
  #205
Old 09-01-2018, 10:53 AM
Saturnine's Avatar
Annnd.. I saw the same thing on my block and Abran had replied with this:
The mark that actually grades the block is under the valley pan on either cylinder 5 or 6. Most of the time oil has eaten it away. It’s a simple paint dab in either blue, yellow, or red.
So, i think everyone has the green marks but the other colors mentioned above indicated the block grade, red being the best.
  #206
Old 09-01-2018, 04:23 PM
I think mine is a very special green lol
  #207
Old 09-05-2018, 08:36 AM
Radiator is finally out and so is the crank pulley. Now to the front cover and pan.
  #208
Old 09-08-2018, 02:06 PM
Charlie_V's Avatar
Just throwing this out there... last time I had my radiator out I swapped either a transmission cooler for an oil cooler (or vice versa... I can't recall which is big and which is small) on my setup so I would have two large coolers attached to the radiator rather than one big, one little. I got it from a donor but they are widely available and no combustible fluids are required for the project.
Never one to shy from controversy, it would also be a good time to do the Chevy thermostat conversion. Again, no flames or explosions involved, so a boring project.
  #209
Old 10-02-2018, 03:31 PM
Thanks Charlie.
I did get a new radiator as well. I do have a question. I can't find the jigsaw puzzle for the condenser, cooler and radiator in the RAVE. It is the only thing I didn't keep very good track of when I disassembled. It probably is the thing I should have kept track of. so many parts
  #210
Old 10-03-2018, 01:09 PM
Just before oil pan install
Front cover on
New cam in and at TDC
Cleaned up the pickup
Pulling the old cam
Quick Reply: Our 2001 Project DII
