Output shaft speed sensor?
Old 03-19-2010, 11:51 PM
Rickey_240's Avatar
Default Output shaft speed sensor?
Codes displays P0722 Output shaft speed sensor. Anyone know where i can buy one?
Old 03-20-2010, 07:48 AM
Either the dealer or a tranny shop can order one.
Old 03-20-2010, 09:04 PM
Rickey_240's Avatar
Do you know around how much they "should" be?
Old 03-21-2010, 09:41 AM
You'll have to call around and see.
How is your truck shifting, any problems, if so exactly what and have you tried clearing the codes, do they come back??????????????????
Old 03-22-2010, 08:03 AM
Rickey_240's Avatar
9 times out of 10 it will stay in first gear till I hit around 25-30mph then it goes into 3rd gear limp mode. And yes I have cleared the code and yes it does come back. The guy who sold it to me says that he thinks it's something electrical, for my sake i hope he's right.
Old 03-31-2010, 10:03 AM
Rickey_240's Avatar
Question
Any suggestions? What would happen if the tranny was bad? Cause sometimes it shifts through all 4 gears then it will rev like it's in neutral and bang 3rd gear limp mode.
Old 03-31-2010, 10:18 AM
Rickey_240's Avatar
This guy has the exact same promblem I do. Except he didn't specify whether he replaced the speed sensor or the output shaft speed sensor.
http://en.allexperts.com/q/Land-Rove...ver-Series.htm
Old 03-31-2010, 08:21 PM
Urban Panzer's Avatar
Have you tried an oil and filter change ? can make a world of difference to a slush box.
Just for info the output speed sensor :-
ZF PART No is 0501-310-401
Old 04-01-2010, 05:18 AM
Rickey_240's Avatar
yes, i change the oil drove it around then changed it again. i'm gonna do the trans fluid just for the hell of it next.
Old 05-05-2013, 06:29 PM
mydisco03's Avatar
Hi disco mike.... Today I was off roading with my 2003, and it was on D, I try to go up a hill twice and then the truck went into neutral... I can select reverse or 1 gear. If I take off on 1 gear then D the truck will shift fine, but if I stop, it goes to neutral... any ideas.
Quick Reply: Output shaft speed sensor?
