over heated....
Old Aug 3, 2010 | 09:27 PM
jrm123180's Avatar
Default over heated....
I over heated tonight. what should I do? just came on. do the thermostats usually fail on these? Coolant was squirting out of the overflow (yea, I had a nasty brain fart and opened it...got scalded bad)
Any advice on this over heating? Where should I begin to look? can I test the thermostate in this?
Thanks again!
Steve
Old Aug 3, 2010 | 09:36 PM
Here is what the thermostat looks like.
http://www.roverparts.com/Parts/PEM100990.cfm
Top off the coolant AFTER it has sat all night.
If you are not mechanically inclined I would suggest you take it in and get it looked at b y a shop.
It does not have to be a Rover shop, any auto shop can do it.
Old Aug 3, 2010 | 09:37 PM
Wheelsonly's Avatar
Why not just replace the stat a 30 dollar part is so much easier then yanking the heads and paying for machine work in the future..
Old Aug 3, 2010 | 09:42 PM
jrm123180's Avatar
although it may not seem it, i am mechanically inclinded....I am in the process of replacing the evaporator for the a/c in this thing...(major job)
Anyhow, I will replace the thermostat in hope that it failed.
FlyingZebra34
Mar 23, 2013 06:34 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
Bayer
Jul 31, 2011 07:39 PM
mddisco
Dec 27, 2004 11:41 PM
