Overheating
Old Aug 5, 2017 | 11:49 AM
Reno_benoit_30's Avatar
6th Gear
Default Overheating
i have a 2001 disco2 and ive changed thermostat , water pump and the system is still pressuring up and coolant overflows from tank . Should i go for rad change or head gasket next ? Thanks in advance
Old Aug 5, 2017 | 01:29 PM
ReceptionRover's Avatar
That's quite the introduction RB.. sorry to hear that you're having troubles with your Rover. I'd suggest to post your question up in the DII section of the forums accessed by clicking on 'Forums' in the upper left hand corner and then 'vehicle line-up' and Discovery II. Hopefully the answer is something simple (and not head gaskets!) - someone should be able to point you in the right direction there. Welcome to the forum and good luck!
Old Aug 10, 2017 | 05:44 PM
freedisco's Avatar
Welcome. Hope its an easy fix!
forbin10
Dec 1, 2005 07:55 PM
Ash A
Nov 15, 2005 01:38 AM
edthediscoman
Oct 5, 2005 01:58 PM
cowgirl1989
Aug 30, 2005 03:31 PM
bakerww
May 24, 2005 09:35 PM
