overheating
Old Apr 1, 2019 | 12:00 AM
dealbergaria11's Avatar
Default overheating
I went offloading today and I put my d2 in low range for about 5 minutes and kept the rpm relatively low and then the temp gauge started spiking. I disengaged low range and the needle fell back to normal within a minute or two. Car has been running normal since then. Any idea whats wrong?
Old Apr 1, 2019 | 08:39 AM
Best4x4's Avatar
I’d say fan clutch, because in low your engine is running higher RPM’s & if the fan clutch isn’t engaging to pull in more air thru the radiator = overheat. Then when back in high it cooled down due to lower RPM’s.
You don’t have your profile filled out or a signature with D2 specs, but on a 99-02 just replace the fan clutch with a hayden 2781/2991. On an 03-04 you’d use the same fan clutch plus a Dorman 620-112 fan blade (03-04 assembly is a one piece design).
Old Apr 1, 2019 | 10:25 AM
Richard Gallant's Avatar
I agree with Best4x4 on this , my Disco loves low range. Mine never heats up in low, if temps are good everywhere else the fan clutch is probably the issue.
Old Apr 1, 2019 | 04:31 PM
redwhitekat's Avatar
Get a ultraguage don’t rely on your dash gauge
OffroadFrance
Feb 18, 2015 06:32 AM
zombiedisco
Jul 16, 2012 05:10 AM
Snafu / Disco Fries
Jan 7, 2012 08:45 PM
Savannah Buzz
Apr 23, 2011 09:08 PM
geoffthepoolguy
Jul 27, 2010 05:06 PM
