Overheating
Old Jun 1, 2019 | 03:12 PM
Saturnine's Avatar
Which tstat do you actually have? Same ones but returned 2 of them?
Old Jun 1, 2019 | 06:14 PM
redwhitekat's Avatar
Replace your thermostat with a 180.
If the lower hose is cold your Thermostat is not opening
there were several thermostats circulating around our vendors they people are having issues with
get the warm weather soft spring from Atlantic British
Old Jun 2, 2019 | 08:08 AM
shanechevelle's Avatar
No offense but I'm laughing at the bad stat comments.
Old Jun 2, 2019 | 09:16 AM
Landy-04's Avatar
Any updates blanco? I’m in the process of fixing mine.
Old Jun 2, 2019 | 09:50 AM
Jeff Blake's Avatar
Originally Posted by shanechevelle
no offense but i'm laughing at the bad stat comments.
Old Jun 2, 2019 | 09:53 AM
Landy-04's Avatar
smh..
Old Jun 2, 2019 | 10:17 AM
He is not overheating
these are the right temps for a oem thermostat
Old Jun 2, 2019 | 10:32 AM
Landy-04's Avatar
Originally Posted by Landy-04
Try this, rev your engine to 2500-3000 rpm and monitor your temps see if they go down. If so, you may have a flow problem. The lower hose will always be a tad bit cooler then the top. But should still be warm to touch. 220 degrees is warm but not overheating. Check your condenser fan see if it’s coming on at all. Check your serpentine belt make sure it’s routed correctly.
Exactly!
Old Jun 2, 2019 | 10:33 AM
Landy-04's Avatar
But even with stock t stat that’s on the higher side.
Old Jun 2, 2019 | 10:38 AM
His idle goes up to 222 so I’m guessing when driving it’s way lower.
My 03 on a stock thermostat when I bought it was hitting 225
