overheating problem
Old Dec 27, 2009 | 12:25 AM
  #21
Mrmerlin's Avatar
I would pull the spark plugs and inspect them.
any that are very clean .
Any that might have rust on the electrodes
Any that dont match the others indicate a coolant leak.
Get an IR gun and check the radiator for inlet /outlet temps.
Replace the coolant bottle cap.
Run another test for hydrocarbons in the coolant bottle vapor, NAPA sells a block tester for 50.00
Old Dec 27, 2009 | 09:31 AM
  #22
2000 Disco 2 SD7's Avatar
Even after a pressure test showed zero loss? After mine held pressure for 20 minutes, I moved on to the next item (current check for A/C fan).
Old Dec 30, 2009 | 01:37 PM
  #23
Default cooling problem persists
Okay - to recap, my Disco overheats after driving for a couple of miles only. Here's what I've done to try to fix the problem:
pressure test at tank - held pressure for 20 minutes with no drop in pressure (19.5 lbs)
replaced A/C condenser fan and validated operation
replaced thermostat and validated operation
replaced water pump
replaced radiator
replaced top and bottom hoses
replaced serpentine belt, and yes - it is installed properly.
Viscous fan spins as seemingly intended
After talking with Disco Mike, next step is perform a chemical block test or exhaust test on the bottle to see if the head gasket is blown on the exhaust side.
I'll post again after that.
Old Dec 30, 2009 | 07:54 PM
  #24
DiscoArt's Avatar
You might want to install an in line thermostat if your block is OK. My truck was running hot with good block, new head gaskets, new water pump, thermostat, radiator and hoses. My new thermostat was not opening at idle so I installed an in line thermostat and the problem is fixed. The truck can idle all day in traffic and the auxiliary fan does not turn on.
Old Dec 30, 2009 | 11:57 PM
  #25
Mrmerlin's Avatar
OK so if you find no Hydrocarbon vapors in the coolant bottle and the plugs all look tan then I would look at the owners manual for the serpentine belt routing, as many times as the belt can be put on correctly it can also be mis routed and still seemingly function.
The fan should be blowing a lot of air towards the windshield, when the car is first started
Old Dec 30, 2009 | 11:58 PM
  #26
Mrmerlin's Avatar
also need a some inlet and outlet temps for the radiator use your IR gun to determine this HF sells em for 29.00 if you sign up for the online coupon
Old Dec 31, 2009 | 12:57 PM
  #27
HF? Sorry but don't know what that is.
Old Dec 31, 2009 | 01:07 PM
  #28
rankar's Avatar
harbor freight
Old Apr 24, 2010 | 02:14 PM
  #29
replaced water pump
replaced radiator
Viscous fan spins - pushes air very well.
Heater works and stays hot, so doubt if an air pocket or blockage is there
It's been a few months but finally got the intake and head gaskets replaced (bad passenger side) by a good quality independent mechanic who has done this same job multiple times, and guess what? I still have the same overheating problem. Drive it a couple of miles and temperature rises and boil over out of the reservoir tank will occur if I push it.....so.....now my next question is: is there a temperature controller that activates the A/C condenser fan that might be causing this? Any other ideas that I can suggest to my mechanic?
Old Apr 24, 2010 | 11:54 PM
  #30
Mrmerlin's Avatar
you probably have a cracked block behind one of the cylinder liners, a Hydrocarbon test will confirm this, get a tester from NAPA for 50.00 its called a block tester
