overheating problem
Old Apr 25, 2010 | 12:09 AM
  #31
greenwade's Avatar
I read through the posts... i see that you have tried replacing your thermostat, once. If it were me i would try pulling the Tstat out and see if that solves your problem. I have gotten thermostats before that are faulty from the get go. Might solve the over heating problem and might not, but you will just be out some wrench time. Just my 2cents
Old Apr 25, 2010 | 10:37 AM
  #32
2000 Disco 2 SD7's Avatar
Originally Posted by Mrmerlin
you probably have a cracked block behind one of the cylinder liners, a Hydrocarbon test will confirm this, get a tester from NAPA for 50.00 its called a block tester
Just curious - would a cracked block as you described yield any other symptoms like coolant mixed with the oil (which I do not have)?
Old May 7, 2010 | 11:45 AM
  #33
Default go figure
Just got a call from 'the shop' and the latest problem turned out to be a cracked head. My mechanic sent the head back to the machine shop and they confirmed the crack, and as luck would have it they have a set of good heads (from a bad block-engine) that they are offering up as conciliation. My truck is due back to me next week around Wednesday. I'm keeping my fingers crossed!
rgbeard
Aug 3, 2010 05:46 PM
substantialiscious
Jan 8, 2010 09:48 AM
josemex
Sep 15, 2009 09:47 PM
alanski
May 11, 2008 08:02 PM
DiscoBones
Aug 4, 2007 02:01 PM
