Oxygen Sensor
Old Feb 6, 2006 | 11:28 PM
xb70valkarye's Avatar
Default Oxygen Sensor
I recently had the inevatable Check Engine light come on and upon checking the code (P1193) I found out it was HO2S heater circuit inferred open circuit, downstream circuit. I recently changed one of the downstream sensors and am wondering if it is the other one. Do I need a new one? How do I check if it is out of parameters? Could it just need to be cleaned or is it the wiring to the sensor? Appreciate any help...
Old Feb 8, 2006 | 01:52 PM
anonimaus's Avatar
Default RE: Oxygen Sensor
Why did you recently replace the sensor? Was it actually bad? If so, did you use an OEM replacement?
The reason I ask, is that I have not had real good luck with the non-OEM sensors.
From a testing standpoint, the first thing I would do is pull the plug apart on both downstream sensors and measure continuity/resistance with a multimeter.
xb70valkarye
Oct 21, 2009 05:26 PM
vjm530
Feb 7, 2008 07:42 PM
raidernine
Sep 3, 2007 08:22 AM
bonedoc
May 1, 2007 06:49 PM
EATMAN
Nov 10, 2006 12:15 AM
