Oxygen Sensor
Old Mar 6, 2006 | 03:13 AM
xb70valkarye's Avatar
Default Oxygen Sensor
Hello again helpers. Got a 1996 Discovery I. Check engine light came on and the code was P1193, need a new oxygen sensor. Looking around I found one without the connector for just $40. Way less than anything I have found. Does it work? Its the downstream according the the code reader. Help would be appreciated.
Old Mar 6, 2006 | 03:25 AM
MadBilly's Avatar
Default RE: Oxygen Sensor
i used them in mine. just splice the wires together. They are color coded.
Old Mar 6, 2006 | 04:40 AM
Thanks man!
Old Oct 14, 2009 | 09:12 AM
bonzadesign's Avatar
I was wondering where you purchased the O2 sensor for the 1996 disco. Mine is an 04/96 model.
Thanks
Adrian
Old Oct 14, 2009 | 09:32 AM
Any where you want. Unfortunately being a D1, your are not cheap, go on-line and check prices on both Atlantic British as well as Rover Connection.
Old Oct 14, 2009 | 02:23 PM
Default Help on locating sensor
Hello
I see you had found an inexpensive o2 sensor. I have a 96 disco. Is that what you have the part for. If so, do you remember supplier and part #
Thanks
Adrian
Old Oct 21, 2009 | 05:26 PM
britishracinggreen's Avatar
On a 1998 DI, can anyone tell me which wires are signal, ground, and heater wires for the post cat o2 sensors. Got some universals for free and want to give em a try before I spend 150 a sensor.
vjm530
Feb 7, 2008 07:42 PM
raidernine
Sep 3, 2007 08:22 AM
bonedoc
May 1, 2007 06:49 PM
EATMAN
Nov 10, 2006 12:15 AM
xb70valkarye
Feb 8, 2006 01:52 PM
