P0130 after recent O2 replacement?
Old Jul 28, 2013 | 10:44 PM
Tony C's Avatar
Exclamation P0130 after recent O2 replacement?
Replaced all 4 O2 sensors on my '01 Disco II about 2 months ago, and have been DTC-free until yesterday. Only thing that was done was replacing exhaust pipe gasket to manifold on drivers side. Threw P0130 code repeatedly (cleared with Ultra Gauge a few times), but after restart, shows up again. Any ideas? My first inclination is to replace the upstream driver side sensor - maybe it went bad? It's a Bosch unit.
Old Jul 29, 2013 | 01:22 AM
The Bosch ECU manual says that is a shorted sensor, or the voltage from that sensor is below 0.039 volts. You UG should show readings for each sensor.
Old Jul 29, 2013 | 08:16 AM
Tony C's Avatar
Good call, will check that this morning, thanks
Old Jul 29, 2013 | 09:04 AM
roverguy7's Avatar
Watch voltage from key on, and then startup. It should be around 0.45v key on, engine off, and then begin cycling once running.
If harness damage is the case, you probably won't have 0.45v without running.
Old Jul 29, 2013 | 11:12 AM
Contact the retailer and have them warranty the bad 02, it happens even with new 02's.
Old Jul 29, 2013 | 01:41 PM
Tony C's Avatar
Ultra Gauge says Bank 1, #1 O2 reading 0.000 volts. All others are in spec. Can I assume that is the driver side upstream sensor?
s10lowrider1994
Jan 16, 2013 02:28 PM
hriant88
May 29, 2008 07:31 AM
raidernine
Sep 3, 2007 08:22 AM
angasreid
May 23, 2007 02:56 PM
