P0150, p0174 & p1174
Old Mar 3, 2015 | 03:28 PM
cammyr01's Avatar
Default P0150, p0174 & p1174
Just got my codes read. Looks like time to replace the O2 sensors? Any help determining what to do next is appreciated!
Thanks, Cammy
Old Mar 3, 2015 | 04:17 PM
sdhow's Avatar
Check for vacuum leaks. If you disconnected any during the upper intake R&R, you may have a leak. It can throw codes like these. Live data scanner is the only sure way to check the condition of your O2 sensors.
Old Mar 6, 2015 | 05:13 PM
cammyr01's Avatar
I will do vacuum test. If there are no air leaks, do 174 & 1174 indicate front O2 sensors need replacement??
Old Mar 6, 2015 | 08:42 PM
sdhow's Avatar
Live data scanner is the only sure way to check the condition of your O2 sensors. With one of these, you check the output voltage of each sensor while the engine is running. Anything else is a guess.
Rearden Steel
Aug 8, 2014 03:39 PM
baburhan
Sep 20, 2010 02:42 PM
richief556
Aug 5, 2010 09:08 AM
787tech
Jul 9, 2008 02:43 AM
hriant88
Apr 30, 2008 07:33 AM
