Sponsored by: CARiD
Getting a P1174, P0174, and P0150 reading
Old Jul 29, 2010 | 12:19 PM
richief556's Avatar
Default Getting a P1174, P0174, and P0150 reading
I just recently changed out all 4 o2 sensors about 6 months ago. I replaced the wires with a set of Magnacors and bosch platinum plus 4's about a year ago. Anyone have any idea what these codes could mean?
Old Jul 31, 2010 | 07:37 PM
Rovin4life's Avatar
you have a lean condition on bank two. Its either a broken weld on the exhaust flange or intake. I would be that you got oil on the oxygen sensor connector.
Old Aug 2, 2010 | 12:19 PM
richief556's Avatar
thx Rovin, appreciate your help. I knew i had a broken weld on the heat shield which has been causing a vvibration/rattling noise under the truck....which i've been getting around to welding back on. I didn't think that there was a sensor that could read a broken weld. If there is in fact oil on the o2 sensor, will i need to replace the whole sensor? In reference to the heat shield.....do i need to get it welded back on or can i just take the shield entirely off?
Thx alot for your help!
Old Aug 5, 2010 | 12:32 AM
Rovin4life's Avatar
no the heat shield can't be welded back on. it has to be tightened down with giant hose clamps. check napa for them.
What I mean is the weld around the flange of the catalytic converter. But its possible the oxygen sensor is covered with oil. clean and recheck the readings. If it responds under load correctly it is good. if it doesn't then put another one in.
Old Aug 5, 2010 | 09:08 AM
richief556's Avatar
Roger that. I'll check it out this weekend (barring the 97 degree weather we've been getting) and get back to the board as to what I find. Thx again!
Rearden Steel
Aug 8, 2014 03:39 PM
pennohawk
Jan 26, 2011 01:05 PM
baburhan
Sep 20, 2010 02:42 PM
787tech
Jul 9, 2008 02:43 AM
hriant88
Apr 30, 2008 07:33 AM
