P0154, dead for sure?
Old Oct 8, 2009 | 06:36 AM
2000 DII's Avatar
Default P0154, dead for sure?
My tests showed no activity from this front passenger sensor, so I followed the advice from all of the previous threads and checked the connection. It was connected good and I actually disconnected it cleaned the contacts with a few Q-tips and reconnected it. After clearing the codes a few times it still comes up with no activity. Is it definately dead now? It had oil leakage that had drained down into the contacts and I wasn't able to get every bit of it out.
Should I buy a new 02 sensor at this point or is there more I can do?
I'm also getting:
P1174
P0174
I appreciate any help.
Old Oct 8, 2009 | 08:04 AM
okdiscoguy's Avatar
Replace all 4 at the same time. At your mileage, you are due for all of them
Old Oct 8, 2009 | 09:10 AM
I agree, then consider doing an induction cleaning to get rid of a lot of old carbon build up.
Old Oct 8, 2009 | 09:42 AM
2000 DII's Avatar
I have replaced all 4 of the 02 sensors within the last year.
Iv'e been wanting to do an induction cleaning anyway. Never have tried it. I gues I'll give her a shot.
Preciate it!
Old Oct 8, 2009 | 11:36 AM
The only other thing that will cause a lean or rich code would be a MAF, but then you would need to have the same codes for both banks.
Since you have recently replaced the 02's then I would say hold off till you get some additional codes giving you a better indication of what is causing it.
diftspec
Oct 14, 2014 10:59 PM
lipadj46
Jun 10, 2009 08:02 PM
samue23
Jun 11, 2007 07:11 PM
wbstyles
May 17, 2007 02:38 PM
landbeater
May 1, 2007 12:15 PM
