P0160 code with nothing left to check. Need help.
Also, did you get the Rave manual downloaded yet? It's pretty helpful for finding your way around this British marvel of engineering...
You've confirmed the O2s themselves, the wiring to them, and the Catalytic convertors they use are functional. Next, you're going to want to look for things that'll cause fuel to burn wrong (vacuum leaks or air flow measurement issues, fuel flow thru injectors, or coolant leaks in cylinder heads), or the systems that control those things (computers). The order I listed them in is a pretty good way to start, hope it helps.
I do have the Rave manual. Does it have detailed diagnostics to help with this kind of stuff? Also I do know that there is a high pitched squeaking noise that after months of replacing belts I found that it was high pressured exhaust coming from the bottom of the manifold where it meets the cat on both sides. I haven't checked there yet after I installed the new cats but the noise is still there. I was surprised because I put new metal gaskets between them before I installed the new cat. Is it a vacuum leak only when un-measured air is coming into the engine or is it also a vacuum leak when exhaust is seeping out the bottom of the manifolds where it meets the cat?
Yes, on a different vehicle I was surprised to learn that an exhaust leak can cause erroneous O2 sensor readings. I had previously thought that exhaust would only leak out, but I learned that enough fresh air will also leak in to cause an incorrect reading.
I have the EXACT same P0160. New sensor shows the same. Swapped both rears shows the same. Disconnected the sensor completely and live data still the same .445v as before.
Did you solve your p0160??
I actually never ended up installing the copper gasket with the additional clamps. After taking the car to a tailpipe emissions test, the individual said that my emissions was cleaner than they've ever seen before with a vehicle that old and all the numbers were running correctly. That's probably because I installed new catalytic converters hoping to solve the problem. I've come to realize that it very well could have been a small CO2 leak from where the squeaking noises coming from. But I actually believe that it was a malfunctioning engine control module. My wife and I decided that it wasn't worth continuing to dump money into it every month. So we ended up selling it and used that money on a down payment for something more reliable. Sadly I truly miss that off-road legend, but at this point in my life I decided to get something that I could trust for my wife to drive. Hopefully you figure out what exactly the problem would be for you without it being too expensive. Best of luck to you.
Oh okay wow! Yeah it's funny because mine actually Burns very clean also. Runs really strong probably the most power that 4.0 ever put out and it's at 174,000 Miles haha! So I guess I will just search for any type of exhaust or vacuum leak. I actually took it for a test drive with live data and now that bad side is reading fluctuating vaults but now pull us up a code for 02 heater circuit rather than no activity detected. I'm one of those weird people about not wanting to check engine light even when it's running good. I own an lr3 with a 4.4 Jag and so far it's been amazing but gosh those electrical Gremlins that come with the rest of that thing sometimes drive you crazy until you learn that it's pretty much all based on the battery and the alternator. Well thank you anyways I appreciate the response.
s10lowrider1994
Jan 11, 2013 09:26 AM
