P0174 code, Discovery II
I just finished doing a head gasket job on my 2000 Discovery II. It started right up, runs good and no leaks. I noticed a slightly rough idle. So I read the codes and came up with a P0174 system too lean bank 2. Could this be a bad 02 sensor. I did spray the cylinders with oil to prevent rust, maybe that fouled a sensor. I replaced the 2 front sensors about 80,000 miles ago, the rears could be original. The Maf has about 80,000 on it too.
Thank you,
Willie
2000 Discovery II
181,000 miles
Thank you,
Willie
2000 Discovery II
181,000 miles
no, not a bad oxygen sensor. Could be a maf sensor. if you have a code 0734 or 733 with it then yes its a maf sensor. But if you don't double check you tightened the intake and exhaust bolts down. seen a few of them get loose causing issues after a head job.
